Princess calipers
mwillerton
Car(s): Ford Capri 2.8i special - Diamond White
Honda Civic 2.2d.
Yamaha Fazer 600
Princess calipers
Post by mwillerton » Thu Aug 15, 2019 12:40 pm
I am trying to fit Princess calipers to my 2.8. I have some black spring clips but cannot work out where they go? Also do I need spacers? I have 2 shims on the caliper bolt and it seems ok?
Thanks in advance
Re: Princess calipers
Post by Peter-S » Thu Aug 15, 2019 1:56 pm
Thanks in advance
Spring clips maybe for retaining the brake pads?
The bolts need spacing washers that you seem to have and the calipers need splitting and spacing as well so you will also need longer bolts and new seals before bolting back together.
There are some pics part way down this page that may help
viewtopic.php?f=17&t=38650&start=100
mwillerton
Honda Civic 2.2d.
Yamaha Fazer 600
Post by mwillerton » Thu Aug 15, 2019 6:13 pm
Thanks Peter. They are the retainers and I got them in the right place it's just they are too small for the wide body caliper! Got told by the seller they don't bother including the larger size as nobody uses them? Anyway I have sourced new bigger ones. Tha ks for the help
Matt
Post by Mc Tool » Sat Aug 17, 2019 12:09 am
https://www.burtonpower.com/princess-4- ... rk009.html
This is the kit you would need to fit princess calipers. Why not have a look at a willwood caliper kit ? The princess was a good mod 20 years ago .....bit old hat now ,and they weigh a ton ;)
Post by Bug » Sun Aug 18, 2019 2:47 pm
I used the original spring clips.
Cut the spacer in half and put a small spacing 'tube' on the retaining pin to hold the two halves in place.
Fiddly to set up, but worked for years on all th Capris I fitted them on.
Bit of a giggle cutting spring steel in half though. Wear googles cos if they slip they go for miles.
Maybe paint them dayglo orange too, just to have half a chance of finding them again :)
Post by Peter-S » Sun Aug 18, 2019 5:19 pm
That's what I did on the other Capri :)
