Struts and Steering re-build
Post by D366Y » Tue Aug 06, 2019 11:41 am
Hello all!
Just wanted some pointers really to make sure I don't miss anything;
I've taken off both struts and stripped them back into the individual components (part from the dampers which I've left in place currently) and I've also removed the power steering rack and have loosened off the nuts/bolts where necessary so I can take apart each component, clean them all up properly and paint where needed.
My question(s) were about if there is anything else I should do before putting it all back together?
Should I replace the damper as well?
Should I remove the damper from the strut at all or just leave it in place?
Should I replace the wheel bearings at the same time?
I'm also assuming that I should clear off all the old grease from the hubs and bearings and re-grease them when putting it back together?
Same goes for the steering rack - is there anything else I should be doing before/while putting everything back together while it's all off?
Thanks!
Re: Struts and Steering re-build
Post by Andrew 2.8i » Tue Aug 06, 2019 3:52 pm
Hi Danny, according to the Haynes manual, the steering gear has to be kept lubricated with 200ml of SAE40 oil. I assume it's a case of putting half in one side of the rack, half in the other and then turning from lock to lock to distribute the oil.
Post by D366Y » Wed Aug 07, 2019 8:06 am
Thanks Andrew, will make sure I do this once it's all back in :)
Post by Andrew 2.8i » Wed Aug 07, 2019 3:37 pm
Hi Danny,
I've just checked and the Ford Workshop Manual (the orange one) gives the same info.
Thinking about it, while the rack is off the car it might be better to take off one boot to pour in the oil before you refit the rack. Otherwise, it might be difficult to actually get the oil to go into the rack, as I don't believe that there is an oil fill point anywhere in the casing.
Considering the rest of the damage to the steering components on the offside, it might be a sensible precaution to at least replace the bearing on that side. You don't know what sort of impact it's had. The bearings appear to be fairly cheap (£20 + VAT from Tickover).
