Injector collars stuck!
GT4
Car(s): 2.8 injection special
Post by GT4 » Sun Jun 16, 2019 3:36 pm
Anyone got any tips to remove the injector collars? Struggled to get the injectors out and now cant get the collars and seals out from 3 of them.
Worried bits might drop in manifold if i break them out?
brooky
Car(s): XR4x4i, loan of 280 when can get it off my son
Re: Injector collars stuck!
Post by brooky » Mon Jun 17, 2019 8:48 pm
I had to take my manifold off to get them out but I am sure someone has an easier method, good old ford design for maintenance again :wank:
Post by Mc Tool » Tue Jun 18, 2019 12:32 am
What are they made of ?, A bit of plastic or rubber will go thru the mill ok, so maybe tap a thread in em and yank em out with a bolt ....other than that Google it😃
ollyw
Post by ollyw » Tue Jun 25, 2019 7:34 am
Hi
Mine were stuck hard and fast too. They are only rubber believe it or not.
I blocked the port up with some blue paper towel. I felt if that fell in then it wouldn’t last long. I used a small screwdriver to carefully lever the remains away. They came apart in pieces and it was painstaking.
The key thing is not to scratch the alloy.
You’ll be left with a brown grit like residue but this will go with some fine wire wool and a can in carb cleaner. Clean the ports up well. You want a good seal here.
Key thing don’t rush, take your time.
Can’t remember where I got the new seals from now. Don’t they come with a head gasket set?
Olly w
Post by Caprigear » Tue Jun 25, 2019 8:38 am
Use a hot air gun to soften the plastic then they are easier to get out,
GT4
Post by GT4 » Tue Jun 25, 2019 9:46 am
Finally got them out using Martins method as I was afraid to scratch the alloy as ollyw mentioned. Now just got to clean the ports up and get rid of the residue left in there!
