Leaking Rocker Cover
martin l
Car(s): mk3 1984 ford capri 2.0 litre s, white used when i ever i get the chance to drive and look after.
Post by martin l »
Can anyone help me please.
I have a leaking rocker cover on my 2 litre Ford Capri Mark 3 1984 and want to know where I could get a replacement. I also need a new oil filter and what brand is recommended for this. I look forward to hearing from you.
Re: Leaking Rocker Cover
Hello Martin I think we met at the CCI the other week , hope you well , yes give Martin a shout at Capri Gear ( think he on holiday for the week ) or Tickover in Dartford will have one . Welcome to the site and have a good look around . :beer:
Is the rocker cover at fault or does it just need a new gasket - that tends to be the usual issue
martin l wrote: Thu May 30, 2019 8:14 pm
Hi Martin,
I hope you are well and :welcome: to the forum.
I use and recommend genuine Ford EFL90 filters. You should be able to get one from your local Ford dealer, to make it easy the reference number (FINIS) is 1555451.
First change would be the gasket - much cheaper at a few quid rather than a whole new cover! :)
Capri Club sell the gasket and oil filter for a relatively reasonable price, or carparts4less do super cheap ones!
Cosmicbike
Post by Cosmicbike »
worth bearing in mind there are 2 different pinto rocker covers, one has a narrow gasket, the other a wide gasket. The wide will fit the narrow with some trimming.
Rocker covers tend to leak if you overtighten the 10 securing bolts, they need very little torque applied. Over-tightening mis-shapes the area around the bolt head which makes it leak. I had to apply a gentle hammer to straighten mine out when I rebuilt the head, it's now nicely leak free.
brooky
Car(s): 2.0 Laser and XR4x4i.
Post by brooky »
Use new gaskets with some rubberized sealant, nip the fastners, allow the sealant to cure 24 hours then retighten the fixings
Standard cork gasket works for me, seem to last years.
And a Bosch oil filter from CarParts4Less, used those for my last several oil changes.
martin l
Post by martin l »
Many thanks for all your advice to everyone
