Hi
Does anyone know if i can put a 2lt pinto flywheel /clutch and bell housing on a 1.6 pinto engine or must i put new parts on 1.6 thanks les
bellhousing
Re: bellhousing
The bell housing is the same on 1.6 and 2.0 and the flywheels are interchangeable too. You don't mention if you are talking about 4 or 5 speed boxes which have different numbers of splines on the input shafts so just make sure you have the correct clutch.
Re: bellhousing
Hi and thanks for your help and its a 5 speed box cheers
