Capri 2.8 mystery
Ford Sierra XR4x4 2.9 1992
Capri 2.8 mystery
hi, I just got a 2.8i
Hi , I’m new...
I have just got my capri 2.8i
I’m not quite sure why, but my 2.8 engine EYxxxxx (build date 12/84) registered 02/85...seems to have spec of an earlier 2.8 as it has non-colour coded grille/lights, cloth recaros, non-leather gear knob and steering wheel. It’s odd someone would do that , I suppose if the seats were so bad they changed them but why the rest?
Trim code is Q5 which I’m not sure is leather and cloth, axle “L” which may be LSD ? Not sure though, maybe someone can advise?
Does anyone know if ford carried on the 2.8 alongside the 2.8 special for a couple of months? I checked inside the rear seats. No build sheet...shock horror.
Any info greatly appreciated on my vin ...I tried that polish site and it’s rubbish. Cheers
Stu
Hi , I’m new...
Stu
Sierra XR4x4 2.9i 1992
Jaguar XJR 4.0 SC 2001
Jaguar F-Type 3.0S sc 380
Re: Capri 2.8 mystery
What's with all the italics? Just looks weird!
Hi Stu,80s-new-man wrote: ↑Tue May 21, 2019 9:24 pm Trim code is Q5 which I’m not sure is leather and cloth, axle “L” which may be LSD ? Not sure though, maybe someone can advise?
There's a Czech site that is useful for reference (Google translate will be of use for this site):
http://capri.fordever.cz/Tipy/tipy_cz.htm#v%C3%BDroba
If you scroll down it tells you that the L in the axle configuration box refers to the final drive ratio - in this case 3.091:1. As you probably know, that will be the same whether you have an LSD or not.
The trim code Q refers to steel grey from 1983 onwards. Hopefully somebody with a Special can confirm what the trim code on their VIN plate is.
I hope that helps!
Ha ha , I was thinkin that you were going to direct us to a site that translates itallicsAndrew 2.8i wrote: ↑Wed May 22, 2019 5:12 pmHi Stu,80s-new-man wrote: ↑Tue May 21, 2019 9:24 pm Trim code is Q5 which I’m not sure is leather and cloth, axle “L” which may be LSD ? Not sure though, maybe someone can advise?
I hope that helps!
Hi Andrew, much appreciated, I’ve only just joined this forum , glad it’s resulted in one helpful post.
Cheers!
Stu
Cheers!
Stu
Hi Stu,80s-new-man wrote: ↑Wed May 22, 2019 11:10 pm Hi Andrew, much appreciated, I’ve only just joined this forum , glad it’s resulted in one helpful post.
Cheers!
Stu
You're most welcome. I forgot to say....
to the forum. .
Are you looking to swap your grey cloth interior for a half leather from a Special ? I wondered when someone would turn up who had...
My 1983 2.8i should have the grey cloth interior but at some point in it's past has acquired a half leather interior from a 2.8i Special. Its never been a burning issue but I'd quite like to swap interiors with someone to return the car another step closer to it's original spec.
My half leather interior is not worn, torn or scuffed and Id look to swap it for a cloth interior in equally good shape. The doorcards have been cut for slightly larger than standard speakers but i would throw in the speakers so that this wouldnt be a problem for you
What part of the country are you in ?
- Brooksy
- Car(s): 1987 2.0 laser (fair weather car)
Hi and to the forum.
As Andrew says, hopefully someone on here can confirm the details you require.
Cheers.
Cheers.
hi Not_Anumber!
Yes I would definitely be interested in doing that!
My cloth interior is good , I can send pics on email
Can you do the same?
I’m located in Norfolk/ Suffolk borders. Nr. Diss, Norfolk. You can text or call me 07487-272366, cheers Stu
Ive sent you a PM Stu with interior photos.
Chris
Chris
- Car(s): Rosso Red Ford Capri 2.8i Special 1986 D reg (Daily driver)
Hi
I've just checked my 2.8 special trim code on the vin, its also Q5
- T.M.
I have QV on early 1984 2.8i with shark grey cloth interior.
Tom
Tom
Thanks guys, looks like QV = shark grey and Q5 half leather/stripe
Cheers!
Cheers!
The mystery continues. When you pulled up outside my house the other day I could swear you had a shark grey interior. A couple of hours and a few coffees later and it had turned into half leather.
The shark grey looks great in my 1983 car and we both now have age appropriate interiors. Excellent result.
- T.M.
Good job!
excellent all round!! Great to see your car Chris!
