Carb overhaul
- Car(s): Ford Capri 2.0 Laser, a few other cars that aren't Capris
Carb overhaul
I'm slowly restoring my 2.0 Laser, is there anyone out there who would fully restore my weber carb? I just want to give it to someone and get it back as good as new and bolt back onto the car.
Re: Carb overhaul
Forgot to add, anyone still doing totally standard 2.0 exhaust systems?
Re: Carb overhaul
I've seen this guy around on tinternet but never used personally - also depending on how much a refurbished costs it could be worth just buying a new carb (last I checked a 32/36 is around £200?)
Also I'm not sure about the manifold but Karius are the brand that still provide original exhaust parts
- Car(s): 3.0 Ghia
Re: Carb overhaul
Have a look at this recent thread
viewtopic.php?f=10&t=52838&p=369499&hilit=carb#p369491
Hope that helps
Hope that helps
Re: Carb overhaul
Yes, you can still get a full system from Klarius, including brackets, etc. and delivery, for around £90.aikmanmosquito wrote:Forgot to add, anyone still doing totally standard 2.0 exhaust systems?
Re: Carb overhaul
And this is a bog standard system similar to what would have been originally fitted?
Re: Carb overhaul
Yes, standard system.aikmanmosquito wrote:And this is a bog standard system similar to what would have been originally fitted?
Re: Carb overhaul
Ok many thanks
Re: Carb overhaul
No problem, this is from CarParts4Less -
