rear seats
chris_v888
Car(s): pontiac formula 400 (restoration project)
rear seats
Postby chris_v888 » Sun Dec 09, 2018 10:26 pm
hi how does the metal bit come off the rear of rear seat? thanks for any help
Re: rear seats
Postby Peter-S » Sun Dec 09, 2018 10:36 pm
chris_v888 wrote:hi how does the metal bit come off the rear of rear seat? thanks for any help
Chris, do you mean the panel that the carpet is fixed to? There is a 10mm nut hidden under a cut flap in the middle at the bottom of the panel. You'll see it if the seat is folded flat. The top edge has a lip and just slots in place.
Re: rear seats
Postby Not_Anumber » Mon Dec 10, 2018 11:17 pm
For removal opf the rear seat found its easier to undo the nut Peter describes that holds the padded section of the rear seat to the metal and then with that out of the way there is a bit more access to remove the metal parts, brackets and hinges
