Brake master cylinder
Paul Domoney
Car(s): Ford Capri mk1 GT 1972
Post by Paul Domoney »
On my 1972 Mk1 Capri brake fluid is leaking between the plastic reservoir and the brake master cylinder. I cannot see the type of seal and I am reluctant to take it apart in case the seals break and I cannot repair it. It would appear that one can only buy the complete unit which is expensive and not necessary. Can anyone suggest how I can solve this problem . :?
Re: Brake master cylinder
Post by Paul G »
You probably need to contact Martin at Caprigear.
https://www.caprigear.co.uk/mk-1-ford-c ... are-parts/
Paul Domoney
Thanks Paul. Will do :)
