Dislok
Essexsoulboy
Car(s): Capri 280
Dislok
Postby Essexsoulboy » Tue Oct 16, 2018 11:26 am
Now my 280 is back on the road I'm now going to update its security systems.I like the look of the Dislok,seems to have rave reviews,just wondering if anyone else has one or if anyone can recommend anything else that might keep my car safe.What Dislok would I need? I'm guessing a small ? Thanks
Re: Dislok
Postby andyd » Tue Oct 16, 2018 11:32 am
They are a great visual deterrent, and yes a small fits my 2.8. There are 3 locking positions, so when you fit it make sure it spins without turning the steering wheel, but not loose enough it can be prised off.
Wheel clamps are ok too, there are various sorts on :ebay:
In the past I have used both at the same time even though car is garaged.
Re: Dislok
Postby pbar » Tue Oct 16, 2018 12:31 pm
Another vote for Disklok here, the small size fits my Laser standard steering wheel.
I didn't realise it had three locking positions though Andy.
Re: Dislok
Postby Jasonmarie » Tue Oct 16, 2018 1:39 pm
I have the stop lock pro and it’s very good also have a car immobiliser with a 3 red flashing lights . Hope it keeps things safe .
Arya2.0S
Car(s): ford capri 2.0 s
Re: Dislok
Postby Arya2.0S » Tue Oct 16, 2018 5:24 pm
Another vote for dislok here. I've had one since owning the car (coming up 5 years now) and it's great. I keep seeing them on other cars far more valuable than a Capri so they must be doing something right.
Re: Dislok
Postby Andrew 2.8i » Tue Oct 16, 2018 7:18 pm
Yet another vote for Disklok here.
What I've found with the small size Disklok is that the fit is just a smidgen too loose on the 2.8 steering wheel. The simple solution is to run a thin layer of foam around the perimeter to pad it out a bit. As Andy says, you don't want a really tight fit as I think the lock must spin on the steering wheel when fitted.
Re: Dislok
Postby andyd » Tue Oct 16, 2018 7:27 pm
Andrew 2.8i wrote:Yet another vote for Disklock here.
What I've found with the small size Disklock is that the fit is just a smidgen too loose on the 2.8 steering wheel. The simple solution is to run a thin layer of foam around the perimeter to pad it out a bit.
I have a length of bubblewrap inside mine to pad it out :cheers:
Re: Dislok
Postby Fordoholic Nick » Sun Oct 21, 2018 12:31 pm
Yep I also haveva disklok too. Very simple to fit and really feels quality. Seem to remember someone posting here about 18mths ago that he lost his keys to his disklok and it took him the whole weekend to get the thing off his steering wheel. Now if this aint a great reason to get one nothing is !!
pbar wrote:I didn't realise it had three locking positions though Andy.
Yep, Paul you will see three slots you can clamp the bar into before sliding the lock bar into place. I clamp mine into the tightest slot. I also have a disklok wheel cover to protect ny wheel too.
Re: Dislok
Postby pbar » Mon Oct 22, 2018 6:21 am
Ah yes, thanks Nick. Like yourself, I have only ever used it on the closest lock.
Re: Dislok
Postby andyd » Mon Oct 22, 2018 10:01 am
Tightest slot on the Capri, but used the middle slot on the Sierra :wave:
