Headlight wiring block disassemble
stubacca
Car(s): 1984 Ford Capri LS (Resto)
BMW 3er
Post by stubacca » Sat Oct 06, 2018 6:58 pm
After a bit of advice, I'm replacing my original headlights with some H4 units.
I've tracked down what wire does what with regards to sidelights, main etc. Ideally I want to get the pins out of the connecting block that secures onto the back of the lights, so I can swap around the wires and isolate the sidelights to the separate pilot light in my new units.
Can anyone explain a technique to get the pins out of the block successfully. I mean I could just cut the wires and re-spade, but that feels like a bit of a hack.
Stu
Re: Headlight wiring block disassemble
Post by Jasonmarie » Sat Oct 06, 2018 7:05 pm
When your talking headlights there is only one man who knows and his helper . Have a look at this on the forum .
viewtopic.php?f=10&t=51782&p=356016&hil ... ht#p356016
stubacca
BMW 3er
Post by stubacca » Sat Oct 13, 2018 2:47 pm
if anyone finds this looking for the same answer, small thin flat screwdriver is needed to do the job. There is a tab on the connectors within the block, just needs pressing out the way in order for it to be removed out the back of the block.
Actually very straight forward.
