Rubber gear lever gaiter.
Postby Brooksy » Thu Sep 13, 2018 7:45 pm
Hi, I've just joined having purchased a 1987 2.0 laser last week and am busy reacquainting myself with the marque. Can anyone advise if there should be a rubber gaiter that covers the hole where the gear lever goes through the transmission tunnel? The grey interior centre consol gaiter is in place but I thought there should be an additional rubber gaiter that sits under it and acts as a sound insulator/weather proof cover? Cheers.
Re: Rubber gear lever gaiter.
Postby Peter-S » Thu Sep 13, 2018 9:46 pm
Brooksy wrote:Hi, I've just joined having purchased a 1987 2.0 laser last week and am busy reacquainting myself with the marque. Can anyone advise if there should be a rubber gaiter that covers the hole where the gear lever goes through the transmission tunnel? The grey interior centre consol gaiter is in place but I thought there should be an additional rubber gaiter that sits under it and acts as a sound insulator/weather proof cover? Cheers.
pretty sure the answer is 'no'! There should be a piece of foam around the top of the gearbox that keeps road crap out but, particularly if the box has been out, the foam will rot out and crumble. I fitted a cut down Sierra rubber gaitor under thre grey gaitor in my 2.8 for this reason.
Welcome to the forum btw :)
Postby Brooksy » Thu Sep 13, 2018 10:36 pm
Cheers and thanks for your reply Peter; I think I'll adapt another to fit like you've done.
Great profile pic of a Lanc btw!
timfromull
Postby timfromull » Fri Sep 14, 2018 7:21 am
The handbrake has a secondary rubber gaiter underneath the grey vinyl one.......maybe you're getting it confused?
Postby Brooksy » Fri Sep 14, 2018 3:27 pm
Thanks and yep I could well have got it confused. When time allows, I'll remove the centre consol and have a look. It's just that I'm getting road noise coming up from what appears to be the gear lever area, when driving.
