1.6 capri laser1985 relay
Kristian buller
Car(s): Ford Capri laser 1.6 1985 nimbus grey
Post by Kristian buller » Mon Aug 27, 2018 5:41 pm
Hi there , only one side of the relay is working , ive tried taking it apart but only one side of it will click, which is full beam , can you get replacements , thanks kristian
Re: 1.6 capri laser1985 relay
Post by Paul G » Mon Aug 27, 2018 6:00 pm
Contact Martin at Caprigear. I expect he will have one.
Post by Not_Anumber » Tue Aug 28, 2018 12:29 pm
Are you sure it is the relay rather than the stalk switch ?
Kristian buller
Post by Kristian buller » Thu Aug 30, 2018 9:45 am
If i change the conections over at the bottom, as in the conections with the 2 pins on it, so back on front and front on back, when i switch full beam the inside headlights r on full, switch it back, put the lights on full nothing, . i will look at the stalk just to see, thanks.
