If at all!
I'm in the process of stripping the underside of my capri back to bare metal. I've got it down to the base metal, used kurust on any surface rust patches, treated with Pol etch primer and then zinc 182 primer. My plan is to then spray the underside with epoxy 212 and body colour.
Will that lot be good enough or should I have included a seam sealer somewhere along the line?
When to apply seam sealer
Re: When to apply seam sealer
I'd seam seal all joints in the wheel arches and any under the floor just to stop water ingress. Make sure the zinc 182 has cured properly before applying it as the two dry at different rates and cracking of the sealer can happen. I'd also seal the joint between the wing and the drip rail if you've had the wings off as water getting in here will cause rust.
- Car(s): Rat - GONE
Surely the simple answer is....apply seam sealer to all seams that need sealing/
- Car(s): 1987 Ford Capri 2.0 Lazer (under resto)
1995 BMW 320i coupe (fun daily driver)
2005 Suzuki 1200 bandit (sunny daily rider)
2007 Toyota Rav4 (sensible daily driver) - Location: Newport, South Wales
Ok thanks PaulG for the helpful advice
