capri laser 1985 1.6 nimbus grey
Kristian buller
Car(s): Ford Capri laser 1.6 1985 nimbus grey
Post by Kristian buller »
ford capri laser 1985 , 60,000 miles full service history , mot to back up , its done 750 miles in 12 years . I'm going through it , it hold the revs about 2000-2500 , blip throttle goes back ok , cuts out sometimes, smooth when u give it gas , and let throttle off , full gas fine , ultrasonicly cleaned cab , new kit , its a weber 34ich , throttle not sticking , can it be vacum related?? , many thanks
Last edited by Kristian buller on Mon Jul 30, 2018 8:16 am, edited 1 time in total.
Re: capri laser 1985 1.6 nimbus grey
Post by Paul G »
Kristian buller wrote:help
Welcome to the forum, what do you need help with?
Kristian buller
ford capri laser 1985 , 60,000 miles full service history , mot to back up , its done 750 miles in 12 years . I'm going through it , it hold the revs about 2000-2500 , blip throttle goes back ok , cuts out sometimes, smooth when u give it gas , and let throttle off , full gas fine , ultrasonicly cleaned cab , new kit , its a weber 34ich , throttle not sticking , can it be vacum related?? ,just seeing if anyone has had this problem , many thanks kristian
Post by Paul G »
if it's idling at 2500 revs you must have the throttle cable too tight or there is a bad air leak somewhere. Is choke turning off OK?
Kristian buller
Throttle cable if fully closed off on the stop, choke is fully off, tick over fine , throttle is clear when reving , air leak from where is the question , or the million dollar question
Kristian buller
Just to add to that , tick over is normal 900rpm , when it is warm, u come so a stop , 20% of the time when u put your foot on the clutch the revs hold higher 2000-2500 , 80% of the time it comes back down to 900rpm
340truck
Car(s): Rat - GONE
Post by 340truck »
Got to be something sticking....the airflow required to hold the revs at 2500 can't be an air leak below the fuel jet, there wouldn't be enough fuel to keep them that high.
Check the ignition timing with a strobe, especially watch the advance and retard as you rev it. Would be very unusual but it's possible the vacuum or mechanical advance is sticking. Unlikely to keep the revs that high for a sustained period though, as I say there isn't enough fuel through the idle jet to keep them high.
Much more likely the throttle is sticking open, this would explain why the "blip" clears it.
Kristian buller
Many thanks for your advise , i will check this and get back to you , the car runs nice , its never been welded either only light surface rust , its very quite as well . many thanks
Is the choke flap tight on the spindle? It could rub a little if not
Kristian buller
Thankyou to everyone for there help, at the side of the carb it has the return springs, when it was cold it was fine , but when it got running and hot they would cramp up and hold it tight , so a bit more room was needed, step by step we move forward, many thanks again , now i need to look at the lights as only one comes on, and by the way are you suposed to be able to turn the lights on with no key in the ignition , i think not BUT..........
Kristian buller wrote:Thankyou to everyone for there help, at the side of the carb it has the return springs, when it was cold it was fine , but when it got running and hot they would cramp up and hold it tight , so a bit more room was needed, step by step we move forward, many thanks again , now i need to look at the lights as only one comes on, and by the way are you suposed to be able to turn the lights on with no key in the ignition , i think not BUT..........
Thanks for posting the solution, always nice when people do that. The lights will come on at the first position, with no key.
Kristian buller
Ok , thanks for that ,mutimeter here we come
Post by Paul G »
With lights, so long as your bulbs are OK then earths will be the problem in 99% of cases. Clean and check the two earths in the back of the headlight bowls and check the fuses are clean under the headlight relay.
Kristian buller
ok will start there
Kristian buller
Right i have just taken the relay box off with the 4 fusses on it, it was a bit carodid , i took the metal case off and fixed it back on the car , one side worked ok , and the other did not , if i manuly flicked the relay the full beam would then appear, i guess its had it , does anyone now what the flat tab sticking out the bottom of the relay box , is it just nothing , i guess universal
Kristian buller
many thanks , it was the relay.got one from capri gear as mentioned , great thanks
timfromull
Post by timfromull »
I had a Nimbus Grey 1985 1600 Laser back in the 80's....
B496XAG. Don't suppose it's her?
