Ball joint splitter
Posted: Sun Jul 08, 2018 9:49 am
by Pedro 70
Hi to all. Enjoying the weather and the ENGLAND football team!! Can you please advise me on which size of ball joint separator I need to purchase , to release the bottom of front strut ball joint? Track rod tapped out easily but not going to try that on the bottom joint. 86 2.8i model. I would like to save the joint so not a fork type splitter. Thanks. Peter
Re: Ball joint splitter
Posted: Mon Jul 09, 2018 7:28 pm
by nigecapri
MachineMart is my favoured supplier for the scissors type splitter. They only had one size last time I bought one.
https://www.machinemart.co.uk/p/cht222- ... t-remover/
Posted: Mon Jul 09, 2018 10:21 pm
by Bod9084
You don’t need a ball joint splitter just hit the part that the ball joint goes into
Posted: Mon Jul 09, 2018 10:33 pm
by Paul G
Bod9084 wrote:You don’t need a ball joint splitter just hit the part that the ball joint goes into
Getting a scissor type splitter in there will be nigh on impossible unless you've taken the disc and backplate off. A couple of good, well aimed, taps with a large hammer on the eyelet the balljoint goes into should separate the joint without damaging the rubber boot.
Posted: Tue Jul 10, 2018 7:39 am
by fordperv
Have used the scissor type a few times with the back plate and disc still on, the last one I did was so seized I actually snapped the seperator though, even if you do rip the boot your local factors will have a selection that cost pennies, take the arm down and they will match it up
Posted: Tue Jul 10, 2018 8:42 pm
by Pedro 70
Thanks guys, some useful information.
Posted: Tue Jul 10, 2018 9:05 pm
by Bod9084
How I split them is get a long strong bar and lever it down over the top of
The track control arm and under the front anti roll bar use ing the long bar then try to hit it to release
It never fails ball joint splinters just rip the rubber boots
So put the front of the long bar one end under the anti roll bar
Under the rad and if you have some one to help get them to press
Down on the long bar and you hit the strut where the ball joint goes
Good luck
Posted: Fri Jul 13, 2018 8:21 am
by Pedro 70
Thanks again guys, will let you know how I get on after the weekend.
Posted: Fri Jul 13, 2018 9:20 pm
by r2vdh
Ratchet strap on the antiroll bar on the TCA's takes most of the stress away and only needs one person to complete the job.
Just buy a fork splitter and some universal boots cheap as chips.
https://www.screwfix.com/p/laser-fork-b ... 19mm/19907
Then just get a univerisal boot kit from a carparts supplier near you.
