Ball joint splitter
Pedro 70
Car(s): Ford Focus titaniumX daily driver.
Ford Capri 2.8i. Superb, dry days only. Kawasaki GPZ 900R.
Ball joint splitter
Postby Pedro 70 » Sun Jul 08, 2018 9:49 am
Hi to all. Enjoying the weather and the ENGLAND football team!! Can you please advise me on which size of ball joint separator I need to purchase , to release the bottom of front strut ball joint? Track rod tapped out easily but not going to try that on the bottom joint. 86 2.8i model. I would like to save the joint so not a fork type splitter. Thanks. Peter
nigecapri
Re: Ball joint splitter
Postby nigecapri » Mon Jul 09, 2018 7:28 pm
MachineMart is my favoured supplier for the scissors type splitter. They only had one size last time I bought one.
https://www.machinemart.co.uk/p/cht222-ball-joint-remover/
Bod9084
A 1987 2.8i thay are both red
Postby Bod9084 » Mon Jul 09, 2018 10:21 pm
You don’t need a ball joint splitter just hit the part that the ball joint goes into
Postby Paul G » Mon Jul 09, 2018 10:33 pm
Bod9084 wrote:You don’t need a ball joint splitter just hit the part that the ball joint goes into
:agree: Getting a scissor type splitter in there will be nigh on impossible unless you've taken the disc and backplate off. A couple of good, well aimed, taps with a large hammer on the eyelet the balljoint goes into should separate the joint without damaging the rubber boot.
fordperv
Car(s): too many
Postby fordperv » Tue Jul 10, 2018 7:39 am
Have used the scissor type a few times with the back plate and disc still on, the last one I did was so seized I actually snapped the seperator though, even if you do rip the boot your local factors will have a selection that cost pennies, take the arm down and they will match it up
Pedro 70
Postby Pedro 70 » Tue Jul 10, 2018 8:42 pm
Thanks guys, some useful information.
Bod9084
Postby Bod9084 » Tue Jul 10, 2018 9:05 pm
How I split them is get a long strong bar and lever it down over the top of
The track control arm and under the front anti roll bar use ing the long bar then try to hit it to release
It never fails ball joint splinters just rip the rubber boots
So put the front of the long bar one end under the anti roll bar
Under the rad and if you have some one to help get them to press
Down on the long bar and you hit the strut where the ball joint goes
Good luck
Pedro 70
Postby Pedro 70 » Fri Jul 13, 2018 8:21 am
Thanks again guys, will let you know how I get on after the weekend.
r2vdh
Postby r2vdh » Fri Jul 13, 2018 9:20 pm
Ratchet strap on the antiroll bar on the TCA's takes most of the stress away and only needs one person to complete the job.
Just buy a fork splitter and some universal boots cheap as chips.
https://www.screwfix.com/p/laser-fork-b ... 19mm/19907
Then just get a univerisal boot kit from a carparts supplier near you. :)
