lights??
skinto69
Car(s): escorts but want a capri
lights??
Postby skinto69 » Wed Jun 20, 2018 5:04 pm
can anyone help, only 1 headlight working and when you put on main beam it goes out, wiring looks ok from what I can see and so are the bulbs , is there a relay somewhere?
skinto69
Re: lights??
mk2 capri
Re: lights??
Postby Paul G » Wed Jun 20, 2018 8:10 pm
Relay is the square box under the bonnet screwed to the bulkhead, just above where the dipstick is.
Check your headlight earths are Ok before touching the relay as well as the fuses including those in the relay.
Bod9084
A 1987 2.8i thay are both red
Re: lights??
Postby Bod9084 » Thu Jun 21, 2018 7:58 pm
Hi there is fueses under the silver box that is fitted to the bulkhead check them
and the plugs that fir to the back of the lamps and as som one as sed check the earths for a quick
Way to check is run a wire from the — side of battery and earth the lights direct
If that works put new wire from the back of the lights as some times the earth screws can rust
If I can help you eney more just inbox me BOD
