Timing out
Posted: Fri Jun 08, 2018 8:23 pm
by Rosco59
Hi just changed the timing belt everything lined up before the belt got changed. But when I turned the engine over by hand I never tighten the belt tensioner down so think belt has slipped. Now the dizzy and moon and mountain line up but the crank pulley is out what will I do now. Thanks
Re: Timing out
Posted: Fri Jun 08, 2018 9:19 pm
by Paul G
loosen the tensioner and pull the belt off the cam and jackshaft pulleys. Get the crank set to tdc then line up the dizzy and "moon and mountain" and re - fit the belt. Tension it before turning the crank pulley. keep doing this till it's right.
Re: Timing out
Posted: Sat Jun 09, 2018 6:08 pm
by Rosco59
Timing sorted now thanks.
