Ignition coil plug?!
Capriscott
Car(s): Ford Capri Laser 2.0 9 (almost complete restoration)
Postby Capriscott » Sun May 13, 2018 3:46 pm
Anybody know where I can buy the 2 leads which push on to the positive and negative on the ignition coil???
I can use ring terminals but they don't look as good as the old school method.
Rumble
Re: Ignition coil plug?!
Postby Andrew 2.8i » Sun May 13, 2018 3:58 pm
You could try Martin at Caprigear. He should be able to supply the terminals with enough of the correct coloured wire to enable you to join them invisibly into your loom.
