The sun roof on my 86 Laser hasn’t worked properly since I got it. Worked up the courage to take it out today and discovered the nylon guides have been fitted wrongly. The front one is flat side up and flat side down on the other side. Anyone know the correct way up and how should thevrear one look. I would attach a photo but I’ve no idea how to do that here ?.
A photo of how they should look would be great.
Slide and tilt sun roof
Re: Slide and tilt sun roof
If you use flickr that's the easiest way to load photos. Unfortunately i don't have a picture as mine doesn't slide properly either haha. Ayra on here would be very helpful, might be worth trying to search the forum as I'm sure he has done a page on here about taking them out and putting it back in again.
Found his link but the pictures don't appear to be working anymore...
viewtopic.php?f=17&t=51494&p=355896&hil ... of#p355896
Keith S wrote:I would attach a photo but I’ve no idea how to do that here ?
2. Click Choose Images
