Slide and tilt sun roof
Keith S
Car(s): 2.0 laser 1986
Postby Keith S » Mon May 07, 2018 2:25 pm
The sun roof on my 86 Laser hasn’t worked properly since I got it. Worked up the courage to take it out today and discovered the nylon guides have been fitted wrongly. The front one is flat side up and flat side down on the other side. Anyone know the correct way up and how should thevrear one look. I would attach a photo but I’ve no idea how to do that here ?.
A photo of how they should look would be great.
Re: Slide and tilt sun roof
Postby D366Y » Mon May 07, 2018 6:08 pm
If you use flickr that's the easiest way to load photos. Unfortunately i don't have a picture as mine doesn't slide properly either haha. Ayra on here would be very helpful, might be worth trying to search the forum as I'm sure he has done a page on here about taking them out and putting it back in again.
Found his link but the pictures don't appear to be working anymore...
viewtopic.php?f=17&t=51494&p=355896&hilit=sunroof#p355896
Sploge
Car(s): Ford Capri Mk3 2.0s
Postby Sploge » Mon May 07, 2018 11:05 pm
Postby pbar » Tue May 08, 2018 1:47 pm
Keith S wrote:I would attach a photo but I’ve no idea how to do that here ?
2. Click Choose Images
