Exhaust recommendations
tejb1
Re: Exhaust recommendations
Postby tejb1 » Fri Apr 06, 2018 5:50 pm
I have a Sportex system on my 1.6; it's ok on most speed bumps but will scrape if there's anything in the boot. There's a particular set of speed bumps in Watford that always cause an awful scraping noise mind. I did have some problems last year as a rubber mount has deteriorated and as theres not much clearance, ended up with the tailpipe rubbing a tyre.
Postby D366Y » Sat Apr 07, 2018 8:32 am
tejb1 wrote:I have a Sportex system on my 1.6; it's ok on most speed bumps but will scrape if there's anything in the boot. There's a particular set of speed bumps in Watford that always cause an awful scraping noise mind. I did have some problems last year as a rubber mount has deteriorated and as theres not much clearance, ended up with the tailpipe rubbing a tyre.
I had the same problem for a small period of time, new rubbers and re-jiggling the exhaust position along the car solved it for me as the original rubbers had started to crack and perished basically
tejb1
Postby tejb1 » Sat Apr 07, 2018 8:07 pm
It was quite a comical day really. Had run over a screw, went to tyre place. They couldn't repair due to the exhaust having rubbed the inside, so needed new tyres. Noticed the rubber cracked, took a photo to show at the parts shop and dropped my phone, smashing it. So what started the day as going out to spend £20 on a puncture repair cost considerably more!
