My handbrake Switch and brake fluid warning light is not working. I haven't checked the lamp yet but will do that soon. I have restored the MK3 laser but never got the warning light to work. Just wanted a bit of help of the location of the handbrake Switch and what colour cables will be going to this switch?
Handbrake Switch
- Car(s): Ford Capri Laser 2.0 9 (almost complete restoration)
Handbrake Switch
Rumble
Re: Handbrake Switch
Its a simple plunger affair under the handbrake gaiter in the console.
As far as I remember it's just a single brown wire to it, that basically completes the earth circuit when you put the handbrake on.
However, this is also the low brake fluid warning light. You can test by pushing down the rubber centre of the fluid reservoir cap and the light should come on.
Chances of both failing are much less than a simple blown bulb.
Thanks for the reply. You were correct with the wire colour and how many.
I checked the lamp and that was fine but on further inspection I found the tabs to connect the instrument cluster to the lamp were squashed and not completing the circuit.
Tested both handbrake and brake reservoir and all is good.
Rumble
Glad it's fixedCapriscott wrote:Thanks for the reply. You were correct with the wire colour and how many.
And more importantly, you actually bothered to give us feedback! Thank you
W- Mondeo 2.0 Ghia Estate
03 Focus 1.6
This is useful, thanks,I have exactly the same problem but haven't got around to properly looking into it... Will check the same thing!Capriscott wrote:Thanks for the reply. You were correct with the wire colour and how many.
