Radiator
Wintersock
Car(s): Ford Capri laser 2.0
Radiator
Postby Wintersock » Fri Feb 16, 2018 6:02 pm
Hey guys. I'm due to be replacing my radiator some point in the new future... (Asap really).
Is there any upgrades recommended?
Also quick look on eBay.. and radiator for Capri is 160.. and a escort mk2 is 120... Anyone know the difference.. or any alternative which could be any cheaper?
Thanks in advance!
Re: Radiator
Postby Paul G » Fri Feb 16, 2018 6:20 pm
Why don't you see if there is anywhere near you that re-cores existing rads? That may be a cheaper option, but not by much I would expect.
Wintersock
Re: Radiator
Postby Wintersock » Fri Feb 16, 2018 6:42 pm
Hi Paul, ill be honest the thing looks unrepairable... but I'm no expert and I'm unsure how they refurb them lol. All the fins are just falling off when touched.. :(
Re: Radiator
Postby Paul G » Fri Feb 16, 2018 7:46 pm
That's what they replace, they re-use the header tank, base and sides and the rest is new.
Wintersock
Re: Radiator
Postby Wintersock » Fri Feb 16, 2018 7:50 pm
Argh!! Lol.
Thanks I'll take a look at this route :). Thanks Paul.
Re: Radiator
Postby Paul G » Fri Feb 16, 2018 7:55 pm
Letus know how you get on as I've got to get one done sometime in the not too distant future.
Re: Radiator
Postby D366Y » Fri Feb 16, 2018 10:34 pm
https://www.ebay.co.uk/itm/FORD-CAPRI-1 ... SwU9xUNt-L
This is the one I've fitted in mine, slightly larger than standard so does a better job of keeping the car cool, and very shinny, also less than £160 :)
Wintersock
Re: Radiator
Postby Wintersock » Fri Feb 16, 2018 11:19 pm
Cheers Danny. I'll ring a few places up tomorrow/Monday and enquire on getting it a refurb if that ends in up being silly priced I'll definitely have a look at this one.. :) thank you!
Wintersock
Re: Radiator
Postby Wintersock » Sat Feb 17, 2018 3:23 pm
Paul. Rang a few places up. Best I could get was 120! For the sake of it a new one would probably be better so I'm going to go down the eBay route.. I seen one on auction last month go for 50 quid, knew I should have dropped a bid lol. :deadhorse:
Re: Radiator
Postby Paul G » Sat Feb 17, 2018 4:28 pm
Wintersock wrote:Paul. Rang a few places up. Best I could get was 120! For the sake of it a new one would probably be better so I'm going to go down the eBay route.. I seen one on auction last month go for 50 quid, knew I should have dropped a bid lol. :deadhorse:
The alloy one in Danny's car does look good. The only observation I would make is that if your car still has the factory plastic cowling around the fan then the rad in the picture is not fitted with the flanges to fit it. On the sides of the rad there are flanges where it mounts on to the body then a separate flange on the engine side of the rad for the cowling to bolt on to. They may charge you extra to fit this if you need it.
Here is a picture of mine
Sorry it's a bit grubby, haven't finished cleaning engine bay yet.
Wintersock
Re: Radiator
Postby Wintersock » Sun Feb 18, 2018 2:31 pm
Thanks Paul! I don't seem to have the casing :( here's a picture of mine. Looks like they have removed it previously.
https://ibb.co/domuFn
Oh and don't worry about your engine bay, take a look at mine. Lol. Ive not had time to give it a good wash yet. To busy fiddling with bits that need doing :)
Re: Radiator
Postby Paul G » Sun Feb 18, 2018 2:53 pm
Yep, your flanges are there but cowling missing. Whether it makes much difference I don't know, would probably just make the fan draw air through the rad rather than from elsewhere. And it keeps fingers off the fan in theory!
scottman1962
Car(s): Ford mk3ls 1600l
Re: Radiator
Postby scottman1962 » Tue Mar 20, 2018 3:24 pm
[quote="Wintersock"]Hey guys. I'm due to be replacing my radiator some point in the new future... (Asap really).
Got one of the alloy rads, not bad fit but you have to trim the top cover plate to make fit
Capriscott
Car(s): Ford Capri Laser 2.0 9 (almost complete restoration)
Re: Radiator
Postby Capriscott » Wed Mar 21, 2018 4:32 pm
I have removed my viscous fan on my pinto and bought an electric fan from eBay a while back. Made a alloy plate to fit where the old cowling was and mounted the fan onto that. Also added in a temperature sensor switch from maplins which is dead easy to wire up. Just mounted the unit to the alloy plate again and poked the temperature sensor in the radiator. There's an adjustment screw on the unit so I started the girl up and waited for the temperature to go up 3/4 and adjusted the screw so it switched the fan on.
Maplins 12v temperature sensor switch:
https://www.maplin.co.uk/p/kemo-tempera ... -12v-n20dd
12v fan:
https://rover.ebay.com/rover/0/0/0?mpre ... 2058921281
Works an absolute dream and cools the engine rapidly
Rumble
Arya2.0S
Car(s): ford capri 2.0 s
Re: Radiator
Postby Arya2.0S » Thu Mar 22, 2018 8:02 pm
D366Y wrote:https://www.ebay.co.uk/itm/FORD-CAPRI-1-6L-AND-2-0L-ALUMINIUM-42MM-CORE-RACE-QUALITY-RADIATOR-UK-MADE-/400811071210?fits=Car+Make%3AFord%7CModel%3ACapri&hash=item5d523396ea:g:Q1gAAOSwU9xUNt-L
+1 for this idea. I have one of these in my 2.0 and it's brilliant. If anything it's too efficient at cooling the engine as when we had snow the outside temperature was so low that the engine couldn't actually warm up as combined with the silly ambient temperature the radiator was keeping it too cool, but that's obviously a bit of a fluke as we rarely have weather that bad! Lol Brilliant during the hottest summer months, looks awesome under the bonnet and through the grille too, especially if you have a MK2 grille fitted. ;)
Re: Radiator
Postby Fordoholic Nick » Thu Mar 22, 2018 11:35 pm
I don't have the fan cowling either on mine but the rad has the flanges Paul mentioned but I don't really feel the need to get one tbh. Engine never tends to overheat and in a funny way I actually think its great to see the fan in action :wave:
I always wondered what the flanges were for :lol:
Image20170312_162215 by nicholas bowler, on Flickr
Mind you if I am doing any tinkering with the engine running just as Paul said fingers beware !! and I am lucky not to have long hair :lol:
I bought my rad from CCI as their rad was one of the few that has the expansion tank hose nipple feeding off to the right side of rad filler rather than the left as you look at it from the front. Might be a small detail to some but the hose nipple facing left means the expansion tank hose has to do a sweeping 180 degree to then feed back across the engine compartment then around and along the inner wing ( clipped in to fixings ) to the tank. I wanted to keep the expansion hose as less obvious as I could so it just feeds off to the right then down and up to the tank itself. It don't feed along the inner wing clips...which yep I know is how Ford intended... :sorry: :lol:
I think these alloy rads that are made to order you could prob ask for this hose nipple to feed off either left or right. I seen Dannys alloy rad and it does look very nice indeed :)
Martincapri
Car(s): 2.0s
Re: Radiator
Postby Martincapri » Fri Apr 20, 2018 6:43 pm
Hi all. Im thinking of getting one of the aluminium radiator from ebay at £134, got to be a cheaper option than recoreing my old one. Just wondering if you did get one in the end. If so what is it like?
Thanks in advance.
Re: Radiator
Postby D366Y » Sat Apr 21, 2018 9:03 am
Martincapri wrote:Hi all. Im thinking of getting one of the aluminium radiator from ebay at £134, got to be a cheaper option than recoreing my old one. Just wondering if you did get one in the end. If so what is it like?
Thanks in advance.
Mine is great, I love it!
I've had two now (first one got damaged so I had to replace it) and they now fit much better than when I got the first one, look much nicer and do a fantastic job of keeping the car cool, don't think its ever gone over half way on the thermometer even sat crawling along waiting to go into car shows in the middle of summer so I'd definitely recommend one. Especially seeing as they are only slightly more than a standard radiator.
let us know how you get on
Martincapri
Car(s): 2.0s
Re: Radiator
Postby Martincapri » Sat Apr 21, 2018 9:07 pm
Great thanks for the reply danny. I'll get one ordered and let you know how I get on.
