Rear seat backrest removal
Postby Paul G » Fri Feb 16, 2018 5:37 pm
To remove the rear seat backrests is it just a case of undoing the two bolts each side where the catch mounts on the wheel arch and the two nuts and bolts in the centre.
Looks like a pain in the butt job for my sausage fingers!
Re: Rear seat backrest removal
Postby Andrew 2.8i » Fri Feb 16, 2018 6:28 pm
Paul G wrote:To remove the rear seat backrests is it just a case of undoing the two bolts each side where the catch mounts on the wheel arch and the two nuts and bolts in the centre.
Yes, that's all there is to it.
Postby Paul G » Fri Feb 16, 2018 7:53 pm
Cheers mate.
Took the remains of the cover off my 3.0 today and the seats are starting to get a bit of mould on them so stripping out the interior, cleaning it and storing it in the dry from now on until the car is restored.
Postby Bug » Fri Feb 16, 2018 9:19 pm
If you only want to keep the material dry, then you can easily remove the rear pads by simply undoing the 10mm nut in the middle of the back at the bottom, under the semicircular cut in the rear carpet. Then push the protruding bolt in and lift the pad off the frame. Much easier and no fiddly setting up to do afterwards
Postby Paul G » Fri Feb 16, 2018 9:54 pm
Bug wrote:If you only want to keep the material dry, then you can easily remove the rear pads by simply undoing the 10mm nut in the middle of the back at the bottom, under the semicircular cut in the rear carpet. Then push the protruding bolt in and lift the pad off the frame. Much easier and no fiddly setting up to do afterwards
Cheers for that, sounds much easier but I might as well remove the lot as the car is going to be totally stripped later in the year when I get going on it.
Paul.
Postby D366Y » Fri Feb 16, 2018 10:28 pm
Paul.
Glad to hear you're finally starting on it Paul!! :D Can't wait to see it come along when it starts :cool:
Return to “Q & A”
Who is online
Users browsing this forum: No registered users and 9 guests
