Two speed regulator
timfromull
Two speed regulator
Postby timfromull » Tue Feb 13, 2018 4:31 pm
I'm in the process or refurbishing my heater.........new motor etc.
Question is, is there a retro fit regulator for the twin speed or does it have to be the specific Capri/Ford item?
Mines grotty and pretty rotten, I don't want to have to pull it all apart again once the rebuild is complete, so dismissing it as fooked.....especially after putting a brand new motor in.
I also don't want to simply live with a single speed fan, as it will irritate me to buggery.
Anyone had a different route other than a used replacement? :cheers:
Re: Two speed regulator
Postby Andrew 2.8i » Tue Feb 13, 2018 4:40 pm
Do you mean the resistor? If so, Martin sells new ones.
timfromull
Postby timfromull » Tue Feb 13, 2018 5:42 pm
Resistor yes :doh:
Straight after posting my question, I found them on Martin's site.........i didn't realise he did remanufactured ones, thought it would be a good used route.
I'll contact him.
Thanks Andrew.
