Electric Fan Installation
Posted: Mon Jan 22, 2018 5:08 pm
by Toxcity
Hi guys - it's been a while!
This has been asked a million times, I know... I've been through every post. I'm wanting to get shot of the viscous fan. It's currently a fan I've nicked from a Land Rover and is oversized and probably sapping a few ponies. I also like the idea of having lots of space around the timing cover etc.
How do people generally wires these up? And where do you get your 12v feed from? I want to get a thermostat to control it, don't trust myself to manually switch it on/off.
First battle is getting the old fan off... I'm going to try the screw driver & hammer trick. ;)
Cheers!
Nic
Re: Electric Fan Installation
Posted: Mon Jan 22, 2018 5:45 pm
by Caprigear
I've done a couple in 2.8i's by fitting an adapter into the bottom tank of the radiator and wiring up the fan via a Ford Focus fan switch screwed into the adapter.
Posted: Fri Jan 26, 2018 11:25 am
by fordperv
Measure the internal diameter of your radiator hose and get one of these to control it
https://m.ebay.co.uk/itm/Stoney-Racing- ... SwUH5aUJym
Just search universal fan switch on ebay
Avoid the ones with the copper pipe that get sandwiched in the pipe with the junilee clip that are adjustable look like a cooker knob, they are utter shite
Posted: Fri Jan 26, 2018 2:41 pm
by Toxcity
Thanks for the heads up! Deffo worth looking into. I was tidying up the loom of the car last night figuring a good place to nick 12v. I removed a aux light which was connected to the second fuse prong from the back of the car. This could be where I nick my 12v (assuming it's switched). :)
Posted: Mon Feb 05, 2018 12:42 pm
by Toxcity
Does anyone know what the inner diameter of the top coolant hose is (Pinto)? I'm looking for the right size thermostat.
Posted: Tue Feb 06, 2018 12:44 pm
by Paul G
Toxcity wrote:Does anyone know what the inner diameter of the top coolant hose is (Pinto)? I'm looking for the right size thermostat.
I think it's a 32 mm Nic. Here's a couple off the bay.
https://www.ebay.co.uk/itm/32MM-HOSE-AD ... Sw2xRYUq1D
https://www.ebay.co.uk/itm/Stoney-Racin ... SwUH5aUJym
With the second one it says in the description that the 100c switch is right for the 82c thermostat.
I'd think about using a relay in your wiring, dependant on how big and powerful a fan you intend to use. The second fan switch says it comes with wiring diagrams.
Posted: Tue Feb 06, 2018 3:06 pm
by Toxcity
Hi Paul! Hope you're well.
Brilliant, 32mm it is. On at 100oC that seems a little late? What would be the down side of going for the on at 90oC? I think I'd like to keep the coolant temp below boiling point if possible. Saying that... I was never aware of what the temp was with the viscous fan.
Posted: Tue Feb 06, 2018 5:10 pm
by Paul G
Toxcity wrote:Hi Paul! Hope you're well.
When the cooling system is pressurised the coolant can be up to 112 - 115c due to being pressurised. The pressurisation raises the boiling point.
Most modern in - radiator fan switches are around 97c upwards.
Here's a link to a Fiesta one and as you can see in the description the operating range is 103 down to 98c.
https://www.ebay.co.uk/itm/Temperature- ... SwnbZYECjX
Posted: Wed Feb 07, 2018 11:04 am
by Toxcity
Righto, 100oC it is! :) I guess I don't want the fan running too often if it doesn't need to.
