Inner wing mudshields
Jim
Car(s): 1.6
Post by Jim »
Hey guys, I'm thinking of installing some inner wing mud shields on my '84 LS. Will I need to make holes in the wings to get the fixings for the mud shields or do the line up with current holes/clip on?
Haven't looked at the inner wings in detail recently and have just had this fleeting thought, so forgive me if it is a stupid one.
Re: Inner wing mudshields
Post by Paul G »
The inner mud shields come with threaded holes that bolt through where the bracket is behind the wheels that secures the wing to the inner arch. The securing brackets need removing (can be a pig as the blts are usually rusted in) and then mudsheilds fit in and bolt in these holes. You will then need to drill a couple of screw holes on the little tags that stick out where the inner arch meets the side panel and screw a couple of self tappers in.
The mudshields need a rubber seal around where they meet the inside of the wing and may need trimming a bit to get a good fit.
Huh , mine has these shields ..... I thought they all did ..... maybe not :)
Jim
Car(s): 1.6
Post by Jim »
Paul G wrote:The inner mud shields come with threaded holes that bolt through where the bracket is behind the wheels that secures the wing to the inner arch. The securing brackets need removing (can be a pig as the blts are usually rusted in) and then mudsheilds fit in and bolt in these holes. You will then need to drill a couple of screw holes on the little tags that stick out where the inner arch meets the side panel and screw a couple of self tappers in.
Many thanks for the above info Paul, much appreciated.
Mc Tool wrote:Huh , mine has these shields ..... I thought they all did ..... maybe not :)
It's my understanding that only later Laser's and 2.8's had them installed as standard?
nigecapri
Post by nigecapri »
2.8 Spec to reduce road noise from the wider tyres fitted to them.
Easy to make from a bit of tin sheet & old door/boot rubber seal.
No need to fix to the outer wing if secured well inboard.
