Mk3 headlamps
Rosco59
Car(s): Ford Capri 2.0s Restoration project
Mk3 headlamps
Postby Rosco59 » Tue Dec 05, 2017 8:33 pm
Hi I’ve got mk3 Capri lights fitted in a mk3 cortina. The problem is the side lights and dipped beam work fine but when on full beam the inner light goes on as it should but cancels out the outer dipped beam and the side light goes on. I’ve tried a Capri relay but it never worked.
Re: Mk3 headlamps
Postby Andrew 2.8i » Tue Dec 05, 2017 8:48 pm
The Cortina relay has wiring that is different than the Capri item. As you say, it switches off the dipped beam when main beam is switched on.
Swapping over to a Capri relay should fix the problem.
Was the Capri relay you tried known to be working? And were all 4 fuses in it OK?
Rosco59
Re: Mk3 headlamps
Postby Rosco59 » Tue Dec 05, 2017 9:43 pm
Hi thanks I did try the relay before i swaped it over and it was working on the Capri. Forgot to say that The cortina had single lights before I changed them.would the light stalk connections be different on a cortina.
Re: Mk3 headlamps
Postby Andrew 2.8i » Wed Dec 06, 2017 5:45 am
Rosco59 wrote:Forgot to say that The cortina had single lights before I changed them.would the light stalk connections be different on a cortina.
On single units, it's usually normal for the dipped lights to go out when the mains come on.
I would check for voltage on the dipped beam live feed into the relay. If you lose that voltage when the mains are switched on, then the wiring needs to be altered to maintain a constant live. It could also be the stalk, as you say.
Caprigear
Re: Mk3 headlamps
Postby Caprigear » Wed Dec 06, 2017 4:54 pm
Later MK2 and MK3 stalks are the same. It could be the relay on the bulkhead, MK2 ones were different.
Rosco59
Re: Mk3 headlamps
Postby Rosco59 » Thu Dec 07, 2017 7:45 pm
Hi thanks for the reply’s how do I going about changing the wiring as full beam definitely cancels out the dipped on the outer light.
Caprigear
Re: Mk3 headlamps
Postby Caprigear » Thu Dec 07, 2017 9:07 pm
You would probably need both wiring diagrams from the capri and Cortina.
Rosco59
Re: Mk3 headlamps
Postby Rosco59 » Sat Dec 16, 2017 6:32 pm
Hi does anyone know where I can buy terminal connector that plugs into the light relay. Thanks
Car(s): 2.8 Injection 1983 weekend use. Restoring:1980 MGB GT + 1964 Honda 250 bike. Previously owned 2 Capris.
Re: Mk3 headlamps
Postby Not_Anumber » Sat Jan 20, 2018 1:51 pm
As an alternative to a relay base you can just use insulated type lucar terminals, crimped on. I always finish them off with a bit of heat shrink tubing.
Return to “Q & A”
Who is online
Users browsing this forum: No registered users and 26 guests
