New sender units
pauliil1948
New sender units
Post by pauliil1948 »
Sender units from retroford international £95 ,anyone used them are they any good,was going to order but thought I would check if anyone one here knows first thanks guys ,Paul.
http://www.retrofordinternational.com/f ... 6843-p.asp
Re: New sender units
Hi Paul,
I haven't bought one of those senders, it does look like good quality though.
Is this for your 280? I'm sure that you will already be aware of this, but the sender is different for the 2.8. On the one shown in the photo, there are two fuel pipe connections.
The Retroford website list the correct 2.8 sender as being out of stock. If your current sender is broken you could try fixing it yourself, as described on this thread.
viewtopic.php?t=46894
Martin at Caprigear might be able to get some stock, CCI also have them in stock.
http://capriclub.co.uk/tank-sender
Post by Caprigear »
Unfortunately I can't find out who supplies these so you'll have to go through Capri Club or Retroford. I would like to find out though.
Post by Paul G »
Caprigear wrote:Unfortunately I can't find out who supplies these so you'll have to go through Capri Club or Retroford. I would like to find out though.
They were being made by a member called "Big J" or Joe as his real name is. He goes by Big J on CP as well.
Andrew 2.8i wrote: but the sender is different for the 2.8. On the one shown in the photo, there are two fuel pipe connections.
True but just take a hammer to the return pipe and flatten it out, then it will work fine :)
Post by Caprigear »
No, the ones supplied by Joe were totally different to the ones being sold through CCI and retroford.
Martin is correct, the BigJ ones look like this:
http://www.ebay.co.uk/itm/Ford-Capri-Mk ... 7675.l2557
Several months ago this was a rare item which could keep your car of the road. Now there are a couple of manufacturers supplying brand new ones. How good is that!
pauliil1948
Andrew 2.8i wrote:Hi,
Thanks Andrew,yes it's for the 280, I sent retroford a email still no reply, and the website says out off stock,thanks again
I have had no reply from text message to this chap, but he does answer the phone which I find is easier anyway.
pauliil1948
Ok Martin
