Disaster!! My recaro badges have fallen off!
both have come off my front seats, they seem to have snapped off from the long plastic plug bits . Once i dig the plugs out from the seat and attempt to repair them does anyone know how they reattach? do i just click them back in? or do they require gluing/taking the seat apart etc
thanks
Recaro badges
- NaisiaN
- Car(s): 1.6 laser 1986. (Toy)
1.4 Renault 19 TR 1989. (Daily) - Contact:
Recaro badges
Jordan
Re: Recaro badges
The ones I have are like this, the long pins push through the seat material and are bent round to clamp them in place
https://www.ebay.co.uk/itm/RECARO-SEAT- ... SwZ1BXeOLa
- NaisiaN
Re: Recaro badges
Wow seems expensive! think ill try and repair mine, How do you access the back to bend the pins around? im guessing taking my seat apart..
Jordan
- Noel
- Car(s): Capri 2.8i
M140i - Location: Twickenham
Re: Recaro badges
Can't you reach up behind the cushion from the side/bottom where the lumbar pad would be inserted?
Assume you have normal Capri fitment Recaros?
Re: Recaro badges
As Noel says, you should be able to slip your hand behind the backrest to retrieve the pins. They are made of metal, not plastic.
Reattaching them with any great success could be difficult. You could always try gluing them in position if you don't fancy forking out for replacements.
Re: Recaro badges
Andrew 2.8i wrote:Hi,
Not a bad shout, rather than pull the pins out and try gluing them back on then pushing it in, just glue the badges straight onto the seat?
- NaisiaN
Re: Recaro badges
brill cheers, i didn't realize you get your hand behind the cushion, first time ive attempted this job. will give it a go.
i may glue them straight on if i cant repair it, although would that cause the seat to start sagging? looked as if the badges pull the cushion tight to the seat.
Jordan
Re: Recaro badges
Hi,NaisiaN wrote:looked as if the badges pull the cushion tight to the seat.
The pins of the badges only go through the fabric and foam, not into the actual metal back support.
- NaisiaN
Re: Recaro badges
in that case i may be able to diy some pins! cheersAndrew 2.8i wrote:Hi,NaisiaN wrote:looked as if the badges pull the cushion tight to the seat.
Jordan
