Wheels Help
Gingerfury
Car(s): 1983 2.8i (in bits)
Wheels Help
Postby Gingerfury » Sun Nov 19, 2017 7:56 pm
Hi all,
I need some help/advice, I have a mk3 Capri with an xpack fitted. I am wanting to know the largest wheel diameter that I can fit on the car. I have changed the front and rear brakes and because of this I will need to run with wheels no smaller than 17”. Has anyone fitted 18” (without having to cut out inner wings and floor pans?
Thanks and hope to hear from you all soon.
-JC-
Re: Wheels Help
Postby -JC- » Thu Dec 14, 2017 10:13 am
Wheel diameter doesn't matter. What matters is what tyres you put on, and the width and offset you use. E.g. with the same width and offset, and an appropriate tyre, it will have almost identical proportions :
http://www.willtheyfit.com/index.php?wi ... &offset2=5
You can get away with a fair bit more inboard width, but not a lot out to the arch. I wouldn't increase the overall rolling circumference too much though as it'll mess up handling, speedo etc. Definitely don't decrease it as it'll look crap!
Also have a look at a similar discussion here that might be useful:
viewtopic.php?f=13&t=51850
Return to “Q & A”
Who is online
Users browsing this forum: iainB88 and 13 guests
