Starting issue
Dreamachine
Ford focus daily driver
Starting issue
Post by Dreamachine »
Hi just asking advise on this please...when I turn the key to start sometimes it will start..and other times there's just a clunk..any ideas
Re: Starting issue
Post by Paul G »
Could be the starter solenoid but that would usually be a click rather than a clunk. The clunk could also signify a duff starter but also check all earthing and wiring connections around the battery, engine and on the starter itself. Is battery in good condition?
If none of these cures it take the starter out and inspect the condition of the gear and, with a small mirror and torch, check the ring gear that goes round the flywheel.
Dreamachine
Re: Starting issue
Yeah it's a new battery..not too sure how long the starter has been on. it looks a bit worse for wear
Re: Starting issue
Dreamachine wrote:Hi just asking advise on this please...when I turn the key to start sometimes it will start..and other times there's just a clunk..any ideas
I had a similar problem on my GL, replaced the starter and problem solved, it has recently started again though so planning to check the connections on that and hope that helps solve the problem so would recommend checking all the terminals on the starter before replacing but sounds like it might need to go...
Taff50ish
Car(s): Capri 2.8 Injection Special, every few days.
Re: Starting issue
Post by Taff50ish »
I've had the exact same problem with my Laser back many Years ago and my current Injection, both were the HT Lead to the starter, corroded up inside the Plastic Sheathing... I would swap this out or strip it back to see how badly corroded the wire is??? Best of luck,
John...
Dreamachine
Re: Starting issue
Cheers guys for the comments
Dreamachine
Re: Starting issue
I've managed to solve this...was due to bad connection on the earth lead to the engine block
Re: Starting issue
Dreamachine wrote:I've managed to solve this...was due to bad connection on the earth lead to the engine block
Thanks for posting, always helpful to know what the solution is :)
