Rocker cover gasket
Dreamachine
Ford focus daily driver
Rocker cover gasket
Post by Dreamachine »
I'm just replacing my gasket..and was wondering do you put sealant on both sides
Re: Rocker cover gasket
I think it is standard practice to put these on dry, i.e. no sealant.
When Edd did the Triumph Stag on WD, he only used sealant on the side which sat in the cover.
sheff
Post by sheff »
I use sealant between the gasket and the cover, as it stops it trying to fall out when you're trying to fit it to the engine. And I apply a light smear of grease to the gasket face that mates with the engine, as it will help when removing it in the future.
Dreamachine
Ok thanks for the reply guys
sheff wrote:I use sealant between the gasket and the cover, as it stops it trying to fall out when you're trying to fit it to the engine. And I apply a light smear of grease to the gasket face that mates with the engine, as it will help when removing it in the future.
+1
