Hey guys, laser 2.0 here.
So I'm waiting at a busy junction go to pull away and the revs dropped, stalled and literally everything died, no turn over, no clicks, no electrics, no nothing. Rolled to side of road and after couple mins everything sprang back to life... So my question is what are we thinking here? Dodgy earth somewhere? (batt, starter motor, alternator all new) any help is as always greatly appreciated!
Engine cut out whilst driving...
Re: Engine cut out whilst driving...
Sounds like a dodgy contact somewhere. Check engine earth and chassis earth straps, main feed to starter and other wires on starter and check the battery terninals are tightening properly espacially if your battery has the conversion to round terminal style connectors.
I'd look at battery terminals, particularly the small black wire that connects to live.
Maybe the condenser on the distributor?
They can overheat and cut out, then come back to life as they cool down.
And age is no guarantee. I've had brand new ones pack up and others go on for 10 years or more
thanks for the useful ideas, turns out it was the thick (neg) lead on batt (potentially the terminal conversion wasnt as tight as needed either) had no power at all when turning the key this morn then a little wiggle of this wire with the key in the ignition and everything came back to life, thus solving the mystery.
*for anyone looking at this later for tips its the thick black V shaped lead that goes from the negative terminal on the battery; one wire to the inner wing and the other bolted to the block under the dizzy.
