Won't rev past 2000rpm under load
SpikeCapri
Car(s): Ford Capri X-Pack 1987
Post by SpikeCapri »
Hi all. I'm having a problem where the capri is revving fine when idle but under load it doesn't want to rev past around 2500prm. Before I start panicking (MOT coming up) is there anything I should be looking out for.
SmokeEm
Re: Won't rev past 2000rpm under load
Post by SmokeEm »
Cambelt could've jumped a tooth.
Crack In dizzy cap
Dirt in dizzy
Points crap
Plugs fouled
Plug Leads
Fuel Pump Diaphram - oo err Mrs
340truck
Car(s): Rat - GONE
Post by 340truck »
Ignition first but if that can't cure it suspect choke flaps (ooh err) stuck in closed position.
I see a thread conversation akin to Daisy's air leak at CoC a few years back coming on........
Just in case, I'll throw in binding brakes.
Capriscott
Car(s): Ford Capri Laser 2.0 9 (almost complete restoration)
Post by Capriscott »
Have you got an electronic ignition or points?
Rumble
Faulty rev counter :xd:
SpikeCapri
I think it is solved now. It seems that the butterfly flaps were sticking slightly. It's still not great on power but then again it could do with a half decent tune up so i'm sure all will be fine. Got it MOT'd today and it is finally back on the road.
