I need a new clutch cable as my old one has snapped, I'm assuming they're all the same regardless of which gearbox I have? Just making sure I'm ordering the right part as I can't afford to wait for it to arrive only to have the wrong part as it's my only car and I use it daily and have no other way of getting around so this needs to be a fast fix.
http://www.burtonpower.com/clutch-cable ... c1148.html
I have a 2.0 pinto and a 5 speed box.
Thanks.
Clutch cable, is this the correct part?
Re: Clutch cable, is this the correct part?
All the cables have the same end fittings but there are at least three different lengths of cable.
Can you advise me on which length I'd need please? The one from Burton is 110cm long. Or can you supply me with the correct part instead?Caprigear wrote:All the cables have the same end fittings but there are at least three different lengths of cable.
Assuming you have both parts still, I guess you could measure it then you will determine which one you have?Arya2.0S wrote:Can you advise me on which length I'd need please? The one from Burton is 110cm long. Or can you supply me with the correct part instead?Caprigear wrote:All the cables have the same end fittings but there are at least three different lengths of cable.
