Hi
I've searched many post on here which advise that you can remove the radio/cassette whilst removing the heater matrix access. But nothing clearly states when asked, "Do I need to take all dash, panels and fascia off just to remove the radio / cassette?"
I want to check the fuse that comes from the radio /cassette unit. Which is the easiest route to do so?
1987 Laser 2.0 radio cassette removal
Re: 1987 Laser 2.0 radio cassette removal
From memory I think the fascia needs to come off, pull the control knobs off and loosen the 14mm nuts that hold the assembly in, or I think you could just unscrew the two mounting plates that attach to the dash frame itself. From below reach up behind and remove all cables (noting where they belong), the fuse should be housed in a black holder or similar that is 'built in' to the wire. (There is another fuse that is in the unit itself also) Pull the unit out of it's black retaining bracket.
However you do it, the fascia and lower panels at minimum will have to come off, it's all pretty simple though.
- Dave1968
- Car(s): Ford Capri 2.0 Laser 1987
Ford Escort XR3i Cabbie 1989
Peugeot 207 XS Sport - Location: Lancashire
Nice one mate! I'll crack on in the morning
Just take pictures as you go. You should find it pretty self explanatory once the fascia is off.Dave1968 wrote:Nice one mate! I'll crack on in the morning
One other thing to note is that if your fascia is still held in by spring clips, to avoid scratching up your dash surround loosen the steering column (two 13mm bolts, doesn't have to be completely off) and drop the column down an inch or two slightly, this will give you the clearance to remove the dash fascia without damaging anything.
- Car(s): 1987 Capri Laser 2.0
I may be wrong, but I think that once you remove the plastic trim from the steering column and release the lower dash on the left of the steering column, you may be able to locate the fuse holder. If I remember right you may see it about half way between the ignition switch and where the ashtray is when the lower dash is fitted.
Hope this may help you.
Don't overlook this step You may really damage the plastic if you try to force it off without lowering the steering columnn slightly.EightyFive wrote:loosen the steering column (two 13mm bolts, doesn't have to be completely off) and drop the column down an inch or two slightly, this will give you the clearance to remove the dash fascia without damaging anything.
Ask me how I know thispbar wrote:Don't overlook this step You may really damage the plastic if you try to force it off without lowering the steering columnn slightly.EightyFive wrote:loosen the steering column (two 13mm bolts, doesn't have to be completely off) and drop the column down an inch or two slightly, this will give you the clearance to remove the dash fascia without damaging anything.
Also please disconnect the battery as I noticed the wires and the fuse holder on mine needed updating as age had just stated taking its time . Any problems with headunit the belt is a really easy job to do , also I have been doing a project with the headunit keeping it looking the same with Bluetooth and may have found a easy solution. More thanks to Andrew then he really knows ( got you thinking ) .
Keep us posted
Keep us posted
- Dave1968
Hey!
Thanks for all your reponses and advice! I've not had time today but I'm hoping to at earliest next week.
I'll keep the thread updated and take some some pics as I go along.
