Power steering
- Car(s): Ford capri 2.0 restoration project
Ford focus daily driver - Location: Burnley
Power steering
Hi ...anybody could help me with this.. there's a strange noise when I turn the steering wheel.theres plenty of fluid in the power steering box..any ideas
Re: Power steering
Yeah the previous owner fitted it
Re: Power steering
Not the answer I see looking for
- Car(s): Rat - GONE
Re: Power steering
But probably the simplest and cheapest in the long run.Dreamachine wrote:Not the answer I see looking for
Re: Power steering
I was just wondering why it was making the grinding noise
Re: Power steering
Try draining and changing the fluid then bleeding the system. To do this have the front wheels jacked up and slowly turn the steering wheel lock to lock. Do this 4 or 5 times at least. Power steering generally uses automatic transmission fluid (ATF).Dreamachine wrote:I was just wondering why it was making the grinding noise
If the grinding persists get someone else to turn the steering side to side (car jacked down) and see if you can identify where the noise is coming from. Strut top mounts are a good starting point. Make sure tyre pressures are blown up correctly. It is normal for PAS systems to make a grinding hissing noise on full lock.
Power steering was fitted at the factory on the last few Lasers made, probably just to get rid of leftover racks etc!
Re: Power steering
Thanks paul...I will try that at the wkd
Re: Power steering
I know the o/s tyre is very low ..could this be straining it maybe
Re: Power steering
That's interesting, I was not aware of that.Paul G wrote: Power steering was fitted at the factory on the last few Lasers made, probably just to get rid of leftover racks etc!
OP, I hope you get the issues sorted.
Re: Power steering
Do you know if it is a Capri rack or something sourced and made to fit from another car ? Is it belt driven ( like a V6 Capri one) or is electric ?
Re: Power steering
It's belt driven with a dual pulley
Re: Power steering
Diagnosis should be just the same as on a V6 Capri with power steering.
Does the noise occur at any road speed and stationary. If so, does it still occur with the front of the car jacked up so the front wheels aren't touching the ground. ?
Re: Power steering
I test drove a white one a few years ago, before I bought mine. That had power steering, I always thought it must have been fitted by a previous owner. I actually saw it as a negative rather than a positive thing, as I preferred a car that was ready to drive and experience from back in the day. Perhaps it was factory then?Paul G wrote:
