Carburettor
Dreamachine
Car(s): Ford capri 2.0 restoration project
Ford focus daily driver
Carburettor
Post by Dreamachine »
Hi need help on this....I've managed to get fuel pumped through to carb...but it's overfilling and coming out of the top....any suggestions :?
Re: Carburettor
Hi again
Could be a few things causing this.
1. Is the new fuel pump you fitted of the correct rating for the car. Carb engined cars only need a pump of about 3 - 5 psi max.
2. Most likely culprits for carb overflowing are a) Top gasket on carb knackered. b) carb needle valve not seating or stuck open or c) float in float chamber punctured or its height not correctly set.
I advise you buy a Haynes manual which will tell you how to strip the carb and reset everything correctly. A full rebuild kit with needle valve and all other gaskets for a 32/36 Weber is available on ebay for about £20 if you find you need it.
Hope this helps.
Dreamachine
Re: Carburettor
Ok cheers Paul...thanks for the advice
3 Litre Power
Car(s): 1975 Capri II 3000 Ghia factory manual, 505k kms, Sunset Red, BVR, B.I
1988 Ford Escort XR3i Cabrio, 177k kms, Red, Black Top ( Daily )
Re: Carburettor
Post by 3 Litre Power »
Stuck needle valve will cause the carb to overflow, some light taps with say a rubber hammer should free it up, but just get the carb rebuilt or get a new one.
:burnout:
Oil and Coolant guru
Re: Carburettor
3 Litre Power wrote:or get a new one.
Get a new carb because of a stuck needle valve? Really? Or do you mean get a new needle valve.
Dreamachine
Re: Carburettor
Ok no probs just bought a kit for 20 of eBay. . :cool:
Re: Carburettor
Dreamachine wrote:Ok no probs just bought a kit for 20 of eBay. . :cool:
Probably best policy anyway if the car has been laid up for a long time. Have you got a manual to guide you? Be careful removing the horseshoe clip from the choke pull down lever as it's easy to lose them!
Also clean the outside of the carb before stripping it and work on it on a clean sheet of paper - it's vital no dirt or shit gets inside and blocks any of the jets.
Dreamachine
Re: Carburettor
Ok cheers paul for the advice
Re: Carburettor
I am pretty sure that I have a carb stripdown/rebuild walkthrough with pics, saved from a website which someone posted, before the Photobucket disaster. If you want that just let me know, that's assuming you have a Weber 32/36, you can probably find others around though.
Dreamachine
Re: Carburettor
Ok thanx I'll let you know if I need that
rshyndy
Car(s): Ford Escort XR3i MK5a, Lexus is200se
Ford Capri 2.0 laser MK3 resto project
Re: Carburettor
Post by rshyndy »
If your running a facet fuel pump u will need a pressure regulator. Iv got a Filter King one. Your facet will be running a lot higher than the recomended 3.5psi.
My filter King one has a little gauge on top of a glass bowl with a filter in. You adjust the pressure by turning a little screw in the top
I KNOW MY CAR IS OLDER THAN ME......WHATS YOUR POINT???
Dreamachine
Re: Carburettor
Yeah there is a regulator on it..the one with the dial numbers 1-4
3 Litre Power
Re: Carburettor
It says restoration project on his profile, i assume the car has been sitting for more than a while so the carb is probably past its best as a whole?
If the carb is otherwise ok then no, just a new needle valve.
:burnout:
Dreamachine
Re: Carburettor
Re done the carburettor with a kit off eBay..replaced the needle valve and jets..job sorted :)
Re: Carburettor
Excellent, well done. And thanks for updating the thread with the solution :)
Re: Carburettor
Nice one Dreamachine, hope it's running OK now.
Dreamachine
Re: Carburettor
Yeah seems to be...come across another problem now :banghead:
Re: Carburettor
Dreamachine wrote:Yeah seems to be...come across another problem now :banghead:
Welcome to classic car ownership!!
