Tachometer rev counter wiring issue.
ccmp
Car(s): 1986 2.0s
Postby ccmp » Sun Aug 06, 2017 7:13 pm
Hi I recently purchased a mark 3 Capri 2.0. Rev counter not working.
I've done a bit of reading and realise that there should be a green wire going from -side of coil to the tacho. I've checked with a meter. There is a black wire going from + side to a connector where it joins 3 green wires. One goes to tacho. However when I disconnect the 2 green wires there is still continuity with the other green.
So it's not as simple as swapping over to the - side of coil.
I'm afraid of doing damage or affecting running of the ignition circuit.
I can't find a proper wiring diagram.
Thanks in advance
Re: Tachometer rev counter wiring issue.
Postby Paul G » Tue Aug 08, 2017 10:27 am
I have posted an answer to your question on Capri Power, complete with wiring diagram.
340truck
Car(s): Rat - GONE
Postby 340truck » Tue Aug 08, 2017 3:46 pm
Very helpful if you'd put that wiring diagram on here as well, if the dark side get it so should we!
Postby Paul G » Tue Aug 08, 2017 4:32 pm
I can't really put it on here, it's stored in their technical archive and the chap that took ages making the line drawings is a regular user of the site.
I don't mind putting a few things on but although I don't use CP as much these days, much friendlier lot on here, but nether the less I don't want to get banned for taking the wee wee.
The technical archive stuff alone is worth giving up your email address and password to become a member, as is a lot of the stuff on here.
Return to “Q & A”
Who is online
Users browsing this forum: No registered users and 17 guests
