thermostat housing advice please.
johndavey11
Post by johndavey11 » Fri Jul 28, 2017 4:09 pm
hi, i need to replace the thermostat housing on my 1600 mk2. mine is steel? so maybe an aftermarket part? the only ones i can find on e bay and from other suppliers are alloy. will this still fit ok and they are secondhand.
Re: thermostat housing advice please.
Post by Paul G » Fri Jul 28, 2017 5:13 pm
Most of the housings available now are alloy. I recently put one on my Laser. The only thing I would say is that the thermostat was a bit loose with the fitting kit they supplied with the housing, I'd suggest you buy a new thermostat kit of a good make as well.
Post by Jasonmarie » Sat Jan 19, 2019 3:59 pm
So went down mum & Dads today to start the Capri up and have a drive up and down the drive way .
I checked the water and oil like normal and noticed some white powder type & damp stuff around the Thermostat housing so stated her up and she’s fine left her running for a good 40 mins and all was fine so will need to have new coolant and a new hose and housing . Should there be anything else I should change ? :beer:
Post by Paul G » Sat Jan 19, 2019 4:16 pm
Jason, before you go throwing good money on new parts may I suggest that you loosen the coolant hose clip about a quarter of a turn and then re-tighten it. Clean the old crud off it then give it a while (ie a few weeks) and see if it comes back or is leaking.
What anti-feeeze are you using? Capri's are best just on the old fashioned blue stuff at about 40% Anitfreeze /60 % water which is plenty strong enough for most temperatures seen in the UK and especially for your car which is garaged. This antifreeze mix should be drained and renewed every two years maximum.
Wrong or overstrong antifreeze is the usual cause of the build ups that you mention.
Post by Jasonmarie » Sat Jan 19, 2019 4:58 pm
Cheers for that Paul yes Tickover noticed it last year and put a new jubilee clip on I just think the pipe has had its day as it could be the original . I will get them to flush out the coolent when they do the pipe .
Just looked on line might go for them posh pipes but in black . Did not know if to do the water pump at the same time ?
Post by Paul G » Sat Jan 19, 2019 5:49 pm
You've got more spare cash than I have mate! Hope youget it solved one way or another.
Paul.
Post by Andrew 2.8i » Sat Jan 19, 2019 7:34 pm
Jasonmarie wrote: Did not know if to do the water pump at the same time ?
Why bother if yours is working fine?
The part alone is £45 at Tickover, and that money would buy a lot of tea towels...... :lol:
Post by Jasonmarie » Sat Jan 19, 2019 8:03 pm
your right just thought with having new coolent and thermostat I might get the water pump done at the same time .
When we was going down I did think perhaps I will tax her and give the old girl a run out but the weather looked like rain and also the salt on the roads .
Roll on summer .......... :beer:
Post by Andrew 2.8i » Sun Jan 20, 2019 9:08 am
Jasonmarie wrote: the weather looked like rain and also the salt on the roads .
Yes, same here. We've had lots of cold nights over the last week so the gritters have been out to play. Plus it didn't stop raining yesterday and today doesn't look much better......
Post by Peter-S » Sun Jan 20, 2019 10:11 am
Andrew 2.8i wrote:[ Plus it didn't stop raining yesterday and today doesn't look much better......
Nice and bright this morning, much the same all day yesterday :tongue: :drive:
ImageJan 19 by Peter Smith, on Flickr
Post by Andrew 2.8i » Sun Jan 20, 2019 11:58 am
Lucky you, Peter!
But then, in the past, even a snow shower hasn't stopped you taking your stunning Laser out for a drive... :D
Post by Jasonmarie » Sun Jan 20, 2019 12:29 pm
Your only down the road peter and I see you had the sun . Was pants here yesterday but do have that sea side sun here today . But very cold as always she is looking stunning :beer:
Post by Jasonmarie » Mon Jan 28, 2019 6:03 pm
So I booked mine in for its service and few jobs to be done and having a new thermostat housing , also was talking about the fuel lines and Gus said most are fine and nothing to worry about as looking my tank seems ok and it’s coated in Dentrol from new but Gus said he will have a check .
So booked her in April 2nd as they have this north-east end guy coming in with his spotless Capri as he wants to eat his dinner of the engine , who was they talking about as I don’t remeber Steve saying he had booked his Capri in :lol:
All also having a new front left bumper override fitted as that’s got a small hair line crack and it’s been bugging me . As they done one at the back last year and it looks great :beer:
