Pinto starter motor terminals
-JC-
Postby -JC- » Sun Jun 25, 2017 12:31 pm
Thought I'd replace the starter too as it's obviously been struggling. New one only has two terminals (heavy duty and spade connector) old one has those two plus a round push on one. What's the extra one for? Do I need it? Car was originally an auto if that matters and it's still the same starter from when I had the auto box on there
fordperv
Car(s): too many
Re: Pinto starter motor terminals
Postby fordperv » Sun Jun 25, 2017 12:53 pm
The 3rd one is a feed for the points to boost the power on starting iirc
-JC-
Postby -JC- » Wed Jul 12, 2017 2:41 pm
Well, it worked fine with just the two wires connected. Great to have it up and running again. I'm thinking the extra wire was to do with the neutral-start inhibitor from the old auto gearbox actually. :drive:
fordperv
Car(s): too many
Postby fordperv » Thu Jul 13, 2017 9:50 am
My manual laser has the 3rd one also and the wire connecting to it :lol: im definately sure its to give 12v at the points on cranking
Postby pbar » Thu Jul 13, 2017 10:55 am
Do all the new starters just have the two terminals then? And if so, what happens with that third wire when fitting the new starter?
-JC-
Postby -JC- » Fri Jul 14, 2017 3:14 pm
pbar wrote:Do all the new starters just have the two terminals then? And if so, what happens with that third wire when fitting the new starter?
Don't know if they all have. I went with a high torque one (powerlite) as my old one was struggling a bit with the higher compression. I've just got it tied up out of the way, in case I need it later!
fordperv wrote:My manual laser has the 3rd one also and the wire connecting to it :lol: im definately sure its to give 12v at the points on cranking
Hmm, fair enough! I have electronic igniton with a coil that runs on 12v all the time so I wouldn't have anything to bypass anyway!
Postby pbar » Mon Jul 17, 2017 6:41 am
Ah, I see, thanks! Most likely then, a standard starter will be like for like.
-JC-
Postby -JC- » Tue Jul 18, 2017 1:55 pm
Yeah, would assume so
Return to “Q & A”
Who is online
Users browsing this forum: No registered users and 21 guests
