Whoop Sound When Pressing Brake
Post by pbar » Mon Jun 19, 2017 11:07 am
Occasionally, and randomly, I have started to get a whoop/squeak sound from under the bonnet when pressing the brake. Only lasts a second. I am assuming it is to do with the vacuum system on the servo/master cylinder?
Just wondering what the most obvious things are to look at before I delve in. Thanks!
Re: Whoop Sound When Pressing Brake
Post by Paul G » Mon Jun 19, 2017 12:02 pm
It's probably in the servo Paul, either the plastic valve that plugs into the rubber grommet from the vacuum pipe or the atmospheric air valve on the rear of the servo where the brake pushrod goes in. Get someone else to press the pedal whilst you have a good listen to see if you can hear which it is.
I've got an old servo and I think both are on it so I could rob the bits and send to you if you can't get them locally.
Post by pbar » Mon Jun 19, 2017 12:36 pm
Thanks very much Paul, I appreciate that. I will have a closer listen as you suggest and see if I can pinpoint it, cheers!
Post by Major_Tom » Mon Jun 19, 2017 2:50 pm
pbar wrote:Occasionally, and randomly, I have started to get a whoop/squeak sound from under the bonnet when pressing the brake.
Sorry, that's me. I'll pack it in.
340truck
Car(s): Rat - GONE
Post by 340truck » Wed Jun 21, 2017 5:00 pm
Tom I've told you about this sort of thing before, time to stop now
Post by pbar » Wed Oct 10, 2018 6:17 am
Just thought I would update this as I found the culprit to be a stuck caliper piston.
Post by andyd » Wed Oct 10, 2018 7:13 am
pbar wrote:Just thought I would update this as I found the culprit to be a stuck caliper piston.
Well done Paul :D
Always good to hear what the problems were,what the fixes are and any links to the parts etc.
Post by Jasonmarie » Wed Oct 10, 2018 9:44 am
Glad to here all sorted :cool:
Post by pbar » Wed Oct 10, 2018 10:54 am
Thank you guys :)
Post by Fordoholic Nick » Wed Oct 10, 2018 5:19 pm
pbar wrote:Thank you guys :)
Great that you found what the problem was Paul and you did not have to 'brake' the bank to get it fixed. Sorry I will 'stop' being silly as you must be getting really 'piston' off witrh my gags :lol: :lol: :lol:
Post by pbar » Thu Oct 11, 2018 6:02 am
Now we know where those joke books of Bob Monkhouse went :)
