Wiring a distributor help
- Car(s): 88 toyota mk1 mr2, 88 ford escort xr3i, 89 fiat coupe 2.ol 20v turbo, Nissan 300zx
Hi guys. Just about to get my car going after 3 years. Changed the 1.6 for a 2.0 205, the distributor has 3 wires coming out of it to a plastic plug. The old distributor had two wires and matching connections are in the loom. What wires do I need to get this wired up to the cars loom. Or do I need a different distributor
Re: Wiring a distributor help
Im guessing you have a sierra electronic dizzy from you saying 3 wires on a plastic plug, if this is the case you need the sierra ignition amp and wiring to make it run, if you havnt got this it might be easier to use your original dizzy as the wiring is harder to come by these days
Ive just popped out to tske a picture Does your plug look like this?
