Well I finally managed to get time to get down to the garage today so I thought I would update you chaps.
I fitted a new alternator today, and bleedin hell what a job this turned out to be ! One of the nyloc lock nuts on the bottom bolt was buggered ! It was twisting to so far then just kept twisting and would not unscrew at all. Tried all sorts but finally resorted to a junior hacksaw !!! But....to do this I thought easier to remove the alternator bracket from engine block along with the alternator itself so I could get better access when sawing the bolt off. Now I presumed that I would have three bolts to remove the alternator bracket from the engine block....however on removing the top two the bottom one which is out of sight was missing ! So all along I only had two bolts holding the alternator bracket to the block. Now while I know this was probably enough as its been like this since I owned the car (!) I still get slightly flustered when I see these sort of things. I had thought I had sorted most of these annoying short cuts or just poor workmanship out from previous owners !! Anyway I found a bolt that would fit perfect so having hack sawed the buggered bolt that was causing me grief I could turn my attention to the bracket and I refitted it with all three bolts !
I had some nuts/bolts the correct style/length to refit the alternator back onto the bracket. Removed the cover back on the alternator plug just to double check the three wires were secure. Plugged this into the alternator then having checked the fan belt was in good condition ( not that old) I replaced this and then tighten everything up...job done !!
Now the time came to see if my work had remedied my issues...got these readings...
12.5 Engine off
14.2 engine running
13.8 engine running - lights on
So it looks like it was the alternator all along rather than the battery. Should have been a pretty simple job but as said ran into a stubborn old bolt. Don't you just love old cars !
Took for a run and thankfully everything seems fine. Will pop down over the next couple of days to keep an eye on the battery readings.
Before I go can I just aske some advice please. I only had normal nuts/bolts/washers when refitting the alternator but I am guessing I should fit either nyloc nuts or spring washers to protect against vibration. Do I actually need to use nyloc nuts if I use spring washers or should I use both ? Also stupid question but when using spring washers do you fit them against the underside of bolt head or do you fit them against the nut at other end...or both ?? Any advice much appreciated.
So a good day in the end as it seems like the issue is now sorted.
All the best now and thanks very much for all your replies of advice along the way. Very much appreciated indeed
