Smokey engine
Re: Smokey engine
Thanks for the offer but no thanks!!!!!!!!!! A pint one day maybe?
Arya2.0S
Car(s): ford capri 2.0 s
Re: Smokey engine
Post by Arya2.0S »
Paul G wrote:Thanks for the offer but no thanks!!!!!!!!!! A pint one day maybe?
That will have to suffice I suppose. :mrgreen:
3 Litre Power
Car(s): 1975 Capri II 3000 Ghia factory manual, 505k kms, Sunset Red, BVR, B.I
1988 Ford Escort XR3i Cabrio, 177k kms, Red, Black Top ( Daily )
Re: Smokey engine
Post by 3 Litre Power »
See my thread on replacing valve stem seals, changing them on my Essex reduced oil consumption to pretty much Zero, any oil will be just a band aid fix, it's not that hard, or expensive to do if you have basic knowledge of your engine.
viewtopic.php?f=13&t=51236
:burnout:
Oil and Coolant guru
Re: Smokey engine
+1 for the positive effect of changing valve stem oil seals
+ for the quality of Victor Reinz seals & gaskets .
Arya2.0S
Re: Smokey engine
Post by Arya2.0S »
Not_Anumber wrote:+1 for the positive effect of changing valve stem oil seals
They are pretty much one of the best things ive ever done to the car. Now i can start it up in a car park and not be worried or embarrassed that im gonna create a huge plume of smoke and make everyone point and laugh, or that the wind is gonna blow it all back into the cabin which has happened a few times.
Cosmicbike
Re: Smokey engine
Post by Cosmicbike »
Apologies for dragging up an old thread, but I currently have the head off my pinto and have a set of VR top hat stem seals to fit. They do not seem to locate in a very positive manner on the head, do I need to give them a helping hand with a hammer and socket? Can't believe that they are just held in place by the valve spring pressure?
Ta.
Re: Smokey engine
Mr B wrote:Got to be honest here, I'm prepared for the backlash I may get for saying this but I run all my cars on unleaded and I've never had a problem, I don't use any lead substitute in the petrol, I periodically check all the valve lash and touch wood I've had no issue's
Mr B wrote:
I'm at 40000 miles with no lead substitute used and no issue's so far
Same for me, just unleaded with no additive, driven like that for years now. I always figured that if I did have an issue, I would sort the head then, with the money I've saved from not using additive (that stuff seems very expensive), and if there are no issues then I'm quids in.
Re: Smokey engine
Cosmicbike wrote:Apologies for dragging up an old thread, but I currently have the head off my pinto and have a set of VR top hat stem seals to fit. They do not seem to locate in a very positive manner on the head, do I need to give them a helping hand with a hammer and socket? Can't believe that they are just held in place by the valve spring pressure?
Ta.
That's the benefit of them - the valve springs mean they can't go anywhere whereas standard seals can rise up the valve stems - they shouldn't of course but it happens.
Cosmicbike
Re: Smokey engine
Ta.
So no hammer then, just the valve springs holding them.
andy007007
Car(s): Triumph Stag with Ford essex engine
Re: Smokey engine
Post by andy007007 »
I want to change mine, so just to be clear i need to buy a Valve Spring Compressor Kit and does it have 8 Valve stem oil seals
Re: Smokey engine
andy007007 wrote: Sat Feb 06, 2021 8:30 am I want to change mine, so just to be clear i need to buy a Valve Spring Compressor Kit and does it have 8 Valve stem oil seals
I have done it without a compressor but it is so much easier with one so, yes, get one. And yes, 8 seals.
andy007007
Re: Smokey engine
since then, some place told me 12 needed ?
Re: Smokey engine
Yes, if you`ve got an Essex V6 then you will need 12 as it has 12 valves.
