Hi guys
Changed the timing belt a few weeks ago, fitted a new fanbelt and water pump to boot. Ran the car with the timing belt cover off to check all was ok.
Today I'm refitting the cover but in doing so needed to move the coolant hose in front to give a tiny bit more clearance. In doing so a tiny amount of the water/antifreeze mix spilled on the timing belt, quite a bit p*ssed down onto the fanbelt.
Am I right to think that I shouldn't worry too much about a bit of antifreeze getting on a new timing belt? Sorry, I know this probably sounds super paranoid! Also, the fan belt got a fair bit more on - is this ok to keep, or not?
Out of interest, if a fanbelt goes I assume you stop sharpish, but putting another one on leaves no lasting damage? (I keep a spare in the boot).
Cheers!
Spilled antifreeze
Re: Spilled antifreeze
The coolant spillage won't have caused any lasting damage, although if you've spilt a lot on the fan belt, it may cause it to slip and if that's the case it will squeal. Best to dry it up the best you can.
Yes, simply replace the broken belt with a new one and carry on as before!tejb1 wrote:Out of interest, if a fanbelt goes I assume you stop sharpish, but putting another one on leaves no lasting damage?
- Car(s): Rat - GONE
Spilt antifreeze won't hurt much, I covered the engine of my capris with pretty much every liquid on the car with no probs.
You can run and even drive the car with no fan belt. There will be no drive to the alternator so the battery will run flat in time. There will be no coolant circulation so depending how gently you drive the engine will overheat in anywhere between 10 mins and 2 hours. Only the overheating will damage the engine, and only then if you continue to run after the temp gauge needle is at the top of the red.
W- Mondeo 2.0 Ghia Estate
03 Focus 1.6
Thanks guys. Mopped up with blue roll and run the engine, seems fine. Cheers.
Also good to know that if the fanbelt goes you at least can get off the road to a suitable place to change it!
