Looking to buy a new pair of front discs as i think my old ones are warped, and i can buy a nice vented set for a 2.8 on ebay cheaper than i can get the lower spec non vented ones for the standard 2.0, but will they fit? Not sure if they have different brake calipers or what not so thought id ask first.
Thanks.
will 2.8 front discs fit on a 2 litre?
Re: will 2.8 front discs fit on a 2 litre?
In essence they will fit but the problem is the caliper has a spacer on the 2.8 that makes it wider to accommodate the wider disc. There are also a couple of spacers to locate it correctly on the strut. You can get these bits though.Arya2.0S wrote:Looking to buy a new pair of front discs as i think my old ones are warped, and i can buy a nice vented set for a 2.8 on ebay cheaper than i can get the lower spec non vented ones for the standard 2.0, but will they fit? Not sure if they have different brake calipers or what not so thought id ask first.
Thanks.
If you want standard items I'm sure I have an unused pair of standard discs in the shed that came with some other stuff I picked up earlier this year. Not looking for a fortune for them but obviously heavy to post.
- jimmyted
Yep. As Peter says, caliper spacer kit from Rally Design or Burtons will let you get the wider discs in. You'll also have to remove the metal dust plates on the back, which can be slightly awkward being as they're bolted through part of the steering assembly.
The solid discs are mainly fine on the road, but I did a track day and found the brake fade to be horrendous. Vented discs made a huge difference.
You can see the setup in this vid :
https://youtu.be/VP5I5HTO7uE
Jim
Jim
Peter-S wrote:In essence they will fit but the problem is the caliper has a spacer on the 2.8 that makes it wider to accommodate the wider disc. There are also a couple of spacers to locate it correctly on the strut. You can get these bits though.Arya2.0S wrote:Looking to buy a new pair of front discs as i think my old ones are warped, and i can buy a nice vented set for a 2.8 on ebay cheaper than i can get the lower spec non vented ones for the standard 2.0, but will they fit? Not sure if they have different brake calipers or what not so thought id ask first.
Thanks.
jimmyted wrote:Yep. As Peter says, caliper spacer kit from Rally Design or Burtons will let you get the wider discs in. You'll also have to remove the metal dust plates on the back, which can be slightly awkward being as they're bolted through part of the steering assembly.
Jim
Thanks for the info and the offer Peter.
I was hoping to upgrade the standard discs you see which is why i was looking at the 2.8 ones, but if i need extra parts to make them fit i wont bother. I did look for an alternative however and found these:
http://www.ebay.co.uk/itm/180455191701? ... EBIDX%3AIT
They look pretty good and offer a suitable upgrade and should help prevent the issue i have now which is a warped disc. At high speeds and under heavy braking i get a very severe wobble which must be a warped disc as the steering and tracking is fine and the car brakes straight and even.
These should offer a bit of extra stopping power too because of the grooves.
Does anyone have any experience with this companies' products?
I also have some standard grooved discs if you want s/h. Probably covered about 5,000 miles. I took them off when I changed to four pots.
Yeah? I dont know much about brake discs, is 5000 miles considered a lot? Dont want to skimp on something as important as brakes, especially after the accident.Peter-S wrote:I also have some standard grooved discs if you want s/h. Probably covered about 5,000 miles. I took them off when I changed to four pots.
